Howdy folks.
My 1826 house has *no* - repeat ... NO - insulation in the walls of the first floor. Back in the day you only built a fire to cook; you didn't try to keep the inside of the house warm.
Inside walls are knotty-pine paneling over old lath and plaster walls. The exterior of the house is all cedar clapboard over the wooden fascia.
Inside the walls are 2 to 4 inches of air space.
I want to insulate the walls, but sure don't want to pull down all the interior (or exterior) surfaces to put in batting.
Has anyone used any spray foam insulation inside the walls? The kind that comes in an aerosol can is sprayed through a small hole in the wall, and it expands to fill the empty space.
