Desert Dog
That’s exactly my argument! Whole project inching towards 90K with pavers, fencing and tree removal but not that I am wealthy but you don’t see a tin cup filled pencils over here(Nod to Paulie Walnuts). Do it once and do it right is my motto.I took the advice of my neighbor when doing my build. "You'll have to look at it everyday, so build it exactly the way you want it to look because you don't want to 'regret' anything. Now, I'm in Austin, so my build budget had to be relatively large and adding on a spa was a slight incremental cost compared to the overall project. We went a bit crazy with everything, but the aesthetics of the attached spa, plus the nice spillway feature just looks pro. Now, do we use it all the time? No. Did we REALLY need a pool this size, either? Well, no, but we got it anyway. Justify the expense by not spending the 10k elsewhere!?![]()
Thank you for the great advice.We used our spa at least weekly over the winter. With our heater, the spa would heat up about a degree a minute so even in the dead of winter with 50 degree water temps, you are talking 30ish minutes for it to heat up to temp.
The pro's of a gunite spa are: they generally look better and are more integrated with the pool, there is only 1 body of water to care for
The pro's of a stand-alone spa are: They are more comfortable as the seats are more contoured, you have a lot more options with jets/configurations.
There is no right or wrong answer, good luck.
See ??? Now this is how you roll !! I am dead set against spending $10k to be fairly disappointed, but would gladly spend $15k to be completely satisfied.Hey for $15k you could get both, lol
I was told that the spa would have to close with the pool.I see that you are in NJ. Won't you have to close your pool for the winter? Not sure you can keep just your spa open and close the pool and if so, seems like that might create some problems for the plumbing...
What would a decent standalone run me? And could you suggest a brand?In NJ its stand alone spas. Makes no sense to have attached spa unless your ok with not using it in colder seasons. Once pool is closed spa goes bye bye. Theres no comparison between the 2 either, standalone really are therapeutic. The only attached spas I see are older built pools or the occasional fiberglass combo spa. You can also do a drop in setup where the spa is recessed if the property or grade allows it.
ThankPlenty of good spas out there under 10g. The dealer is as important as the spa. I have a hot springs it's a great tub. Any major brand is pretty good stay away from Costco and budget deals...you get what you pay for. Right now you can barely find a spa or pool for that matter inventory is gone around here. You can often find super nice tubs if you look hard on craigslist and such sites. Nobody buys the newer expensive tubs they mostly look for cheap stuff. Many spend 10k+ and then move or dont use and sell for huge loss
Thank you!!!Plenty of good spas out there under 10g. The dealer is as important as the spa. I have a hot springs it's a great tub. Any major brand is pretty good stay away from Costco and budget deals...you get what you pay for. Right now you can barely find a spa or pool for that matter inventory is gone around here. You can often find super nice tubs if you look hard on craigslist and such sites. Nobody buys the newer expensive tubs they mostly look for cheap stuff. Many spend 10k+ and then move or dont use and sell for huge loss
What did the water feature run you?We had this dilemma. I added a water feature for “looks”, and a standalone caldera for “feel”. Those plaster benches just aren’t comfy and my hot tub has 50 jets!
