SPA Light Turning on by Itself
Tubbs
Active member
Nov 20, 2021
44
Las Vegas
Installed a new PAL evenglow spa light. It has a remote no wifi.
I took the line voltage out of old lights junction box and ran it to the transformer.
Light works fine with the remote but the light comes on at night by itself.
The line power is coming out of a Aqualink controller that is 25 years old.
I have cleared all the programs, turned on the landscape lighting as the
power for them come from the Aqualink box but that did not turn on the spa light.
Any help would be appreciated!
Give us a link to the light you installed.
It sounds like the light remote is independent of the Aqualink.
If the remote turns the light on and off and the Aqualink does not then it is a problem with the light remote.
Show me how the light is wired through your Aqualink.
Your Aqualink should have no control over that light.
All controls come from the light remote.
It’s not really thru the AL I just disconnected the power at the old junction box and moved it to the new transformer is does go thru the GFI on the Aqualink box
Then why did you ask about the Aqualink not turning on the spa light?
Any problems with your light turning on or off are from the PAL remote.
