We moved into our house 4 years ago we had the pool/spa circulation pump replaced with a variable speed pump, but left the old pump that is dedicated to just the spa jets. I did fire it up at that point and it leaked a little in the middle (probably a seal/gasket/etc), but since then we haven't turned it back on in 4 years. I was thinking about trying it again, but in preparation had a few questions.
1) If the pump turns on and runs fine, but leaks, is it worth trying to replace the seals/gaskets/etc, or just buy a new pump since its pretty old?
2) if buying a new pump, what kind of pump do you buy?
a) Are pumps used for jets the same that would be used for regular pool circulation or are there specific pumps for spa jets? Do I just look for say a replacement single speed 2hp pool pump with basket?
b) is it worth buying a variable speed pump so the jets can be dialed in (if they are too hard/soft)? are there cost savings (energy) with not running jets full blast if they are left on for a few hours at a time every once and a while.
3)the spa is also elevated above the level of the pump and it looks like the current spa jet pump has no check valve or on/off ball valve, so I imagine the spa may need to be drained or partially drained (into the pool) before working on the pump. Would it would be worth putting in either a check valve or a ball valve on the input and/or output side of the pump so in the future the pump can be worked on without draining the spa?
Thanks!
Thanks!
