I run my spa at night for 30 mins and discovered I had a sticky actuator valve that was causing the spa to drain down into the pool, but this was after I had both, to be sure, check valves replaced. I also discovered the spa has 2 check valves in each primary within the spa. The new actuator valve was installed about a week ago. No problems until last night.
After the spa ran last night, I found the spa this morning drained almost to the seat. I suppose it could be the new actuator valve, but I'm at a loss if it is not. The pool repairman that replaced the actuator is recommending another check valve on the suction side, if I remember correctly and if the problem persists.
Anyone have similar experience or additional troubleshooting advice?
