Hi All,
Question regarding the drain cover for the spa. My plumber plumbed in a 3" suctions for the spa jets and 2.5" suctions for the spa filter suction right next to each other - total of 4 pipes (attached photo). Is a separate cover needed for these that are VGB approved? or the covers can cover each set of 2 since they're so close to each other. My concern is if a separate cover is required for each, I won't have enough clearance to install them after plaster. Thoughts?
Which cover do you recommend?
Thank you in advance!
