Hi! If anyone here has thoughts on this I’d love to hear. This is what I sent my pool builder. I am not able to attach the videos I referred to in this forum. I’m wondering if the filter has anything to do with this or if this is ‘air lock’ ??
“Hey Dennis! I have a few questions about the spa in general. Has to do with when I just use the regular pump (spa mode) then turn on the booster (spa Mode + booster) then turn the booster off (back to spa mode) Attached videos show what I mean:
Video file 0607 is when I first turn on the spa with main pump only. Video shows jets just pushing some water out, and are not strong.
Video file 0608 is when I ALSO turn on the booster. You can see the jets get very strong.
Video file 0609 is when I turn off the booster. You can see the jets working as they should with ONLY the main pump. (Still pretty strong!)
So basically, whenever i turn on the spa with just the main pump, the jets are weak. But when I add the booster pump, then turn it off, the main pump makes the jets work as they should. I am not sure this is normal? Cause what if I didn’t have a booster pump? How would the I get the main pump to make the jets work as shown in video 0609?
I’ve noticed this for a while - just forgot to ask. Let me know your thoughts.
