Hello all,
First time poster and pool owner. I’ve been around pools for many years and worked on some systems so I have a basic understanding of plumbing and how the systems work. I regularly integrate Jandy and Pentair into home automation systems. Now I get to do it for my own home.
Spa bubbles are nice, but a lot of the time I would like to just have the heater run and have it nice and quiet. My question is, can you put a valve and actuator to choke off the air intake and just let the VSP ramp up to high speed when heating the spa and then open the air intake when you want bubbles?
I have attached a diagram of my system using the Omnigraffle blocks someone so kindly shared. I forgot to add the air intake to the diagram, but everything else should be complete. I believe the side grate in the spa is a return? Could someone clarify that for me?
Thank you!
Brian
Thank you!
Brian
