We are in the process of purchasing a home which has an IG pool and need some advice on going with an automation system since the electrical needs to be cleaned up anyways. we are closing in two weeks so i'm researching options. It has a Chem-Less ozone system which will be going away asap and we already have a TF-100 test kit ready to go.
The pool is currently controlled by an intermatic timer with dual clocks, one is always on and has no trippers and the other has one on and one off. The pool has a single speed filter pump, polaris booster pump and a pump for the waterfall and light is controlled by a switch on the patio. I don't know brands or models of any of the pumps yet but I do know the polaris pump only comes on if the filter pump is on. The pool was installed in 2002 an as far as we know so far there is no GFCI on the light or the pumps.
We definitely want to convert to saltwater do might as well do it now and plan to replace the filter pump with a VS model eventually. I've been looking in the Easytouch with IC40 system and the aquaplus with T-15 system or the prologic. I've read conflicting info as to whether or not the Aquaplus can control a VS pump some saying yes and some saying no and even one saying they control an intelliflo with it.
So with this limited info which system would you go with? Also would you do a GFCI breaker for the whole panel in the house breaker box or would you do indiviudal GFCI breaker in the automation panel for each piece of equipment?
