Solved: diverter causing blockage
I have a DE Filter- Pentair 48 that normally runs around 22lb and is over 30+ now and not filtering. I just installed a new Pentair48 housing and new filter that came with it- 6 weeks ago (using Fibers) because my old 20+yr old one developed a split in the fiberglass top. Yesterday I notice my cleaner not moving and discovered the water is not flowing through the filter. I immediately backwashed and ran clean cycles which ran fine-no priming or pumping issues. I tried the multiport valve on recirculate and water is not pulling from pool. Recap: Backwash and Clean on multiport settings worked fine. Filter and Recirculate not pulling water? Where to start search for blockage or issue? Thanks in advance.
