Does anyone have a picture of their wiring inside the solar touch panel behind the screen? My RS-485 connector that comes from my IntelFlo pump only has the black and green wires connected. This is how it has been since I have had the pool. Do all RS connections need to be used with the comm wire from the pump? I have been having issues with the solar touch throwing pause alarm randomly. Pentair is saying it is because the pump is being manually turned off. Which isnt the case because its in the middle of the night when it goes through a cleaning cycle. This happens completely randomly.
Pentair then said it was the cable that was bad. Kind of hard to believe because it works 50% of the time. Or going back to my origianl questions. Are all 4- black, green, yellow and red need to be connected. The comm cable that is currently installed only has 2 wires from the pump. But the replacement comm wires online are showing 5.
