Hi all, looking to get some input on a solar heater installation. after doing some research, i gathered that roughly 75% coverage was ideal for the north east (i'm in new york, on long island). my pool has been between 76-79 degrees this summer. it has been a very cold summer, so many cold days and rain storms that i haven't bothered using the blanket. last summer i was averaging about 83-85 degrees just using the solar blanket religiously. this summer we hardly swam because the pool has been so cold, as we prefer 85+. ideally 87-90.
So i've been talking with two dealers, one is h2otsun, and one is a local reputable dealer/installer of heliocoil. I'm very handy DIY everything but I'm not really keen on doing a self install since i'm not a fan of going on the roof. That being said, apples to apples comparison for the two systems i've compared give me the following.
I cannot yet find a local installer for the h2otsun panels, so i will compare the parts alone for the heliocoil to the h2otsun, even though i have an installed price for the heliocoil.
panels/associated parts/solar controller (not including labor or long runs of PVC) for the heliocoil for 415sq feet of panel comes to 5,735. labor including trenching and long pipe runs is another 2100. 12y warranty on the heliocoils if installed professionally.
panels/associated parts/solar controller for the h2otsun for 600sq feet of panel (horizontal orientation fewer headers) came to 4,300.
My roof gets a ton of sun with no obstruction for pretty much the entire day. it is south facing with little wind. my pool is 20x40, and traditional measurements would imply a volume of roughly 30k gallons. However, after doing many chemical additions and seeing how my water responds to a given amount of any chemical, i have arrived at my pool being roughly 22,500 gal. it has a very shallow end, and the 8ft deep end has a lot of beveling with only a small portion actually beeing fully 8ft.
Obviously the heliocoils are more expensive and for fewer panels, but they are the only ones i can find a local installer to actually put in. my biggest concern is the difference in performance between 415 sq feet and 600sq feet. I only use the pool between may and september and would be using a blanket. in order to try and get 600ft of heliocoil, including labor, it quite frankly just gets out of hand budget wise. So the question is, is 415 square feet sufficient? or should i try to find someone who will install the other system in order to try and get more coverage for roughly the same installed price.
does anyone have any input with regards to the performance of their solar heater in the northeast based on a similar situation? should i just keep it simple and go with the local dealer/installer with the 415 feet or should i hold out on trying to find someone who will install the 600ft of h2otsun panels? Am i going crazy and going overkill expecting that i need 75% coverage for optimal performance?
