I'm familiar with HotSun (hopefully I'll be able to finish by the weekend), so I'll tell you why I like them and how you can do DIY using this approach. Also, like most, since I went with this company, I'm obviously biased! But just because I parnoid doesn't mean they are not out to get me!
Why I chose H2otSun:
- PVC. More robust material, more heat resistant, and higher pressure capability (less chance of blowout if valve is open and pump is at full bore, etc.
- Flexibility. You can make arrays 2' or 200' long, route around obstacles, and/or turn corners.
- Simpler plumbing (usually).
- Good for DIY. The plumbing design is far trickier than I thought. In fact, had I plumbed my (simple!) setup like I initially thought, I'd have not known that 1/2 my array eff ctiveness wouldmhave been lost.
- Terrific advice, support review. I sent my approach to Ken and he showed me the places where I could fix, improve, and optimize.
- I think normally this would be somewhat higher than the more standard arrays, but for me, slightly less array cost since the install flexibility allowed me to put in 2 large arrays vs 12 smaller (and less effective) arrays. Or, said another way, because of the flexibility, I didn't need as large an array, plus significant pot fewer headers and subsequent plumbing.
- Easily repairable. Or more like extremely repairable.
In summary, if the standard arrays are an easy install, I'd think these would be a better deal (e.g., helicoil). But if you want an easy install with plenty of tech support, and the standard array sizes don't work well for you, H2otSun may be a better choice.
So, you have 254 sq ft surface area. So you want between 70 and 100% (rule of thumb). More if you want very warm and don't cover, less if you don't need as much temp increase and you have a cover.
254 x 0.7= 177 sqft
With Ho2Sun, the rolls are ~90' long, so for a no waste system, a 180 sqft system would be 6' wide. Since a roll is 4" wide (three strips per foot per header), just add another roll and 2 more headers, and you have 7' or 210, another roll and 2 headers yields 8' or 240 sqft etc.
in fact, you could leave space and plumbing for 9', but start at 5' and then add 2 headers and a row if it is not enough.
we can help more with more info:
1) direction the fence roof faces (directly south is very good)
2) is the fence completely unobstructed from the sun?
3) How windy do you think it normally is?
4) how high is the bottom of the array from the pool pump in elevation?
5) what angle is the array (is it angled toward the sun?
