- Aug 31, 2019
- 298
- Plaster
- CircuPool RJ-60 Plus
Hello TFP,
I'm in the process of researching solar covers and have a few questions:
Long version:
Short version:
Long version:
- I want to keep the cover on during fall/spring so that I can run my heater and not waste money. I want to keep the cover on during the winter to keep debris from falling in while we aren't using the pool. In this post it's mentioned the water needs to "breath" to release the CC, if I take the cover off once a week to brush the pool, will that be enough? I figure to put in chemicals I'd just pull back the cover a little bit since I'll be putting in chemicals much more than once a week.
- I have a suction side vacuum attached via a vac port. I'm concerned that the hoses will be too close to the surface and be impeded by the cover, is that something I need to worry about?
- Right now I have about 50/50 pressure to the vac port and 1 skimmer, nothing to the main drain or 2nd skimmer because my pump doesn't seem to have enough suction. My VS pump runs with basically 2 settings, low setting where the skimmer works well, and the high setting where the vacuum works well. I assume with the cover the skimmer(s) won't be working at all, I figure I'd adjust the pressure to the vac port and/or main drain to get the water circulating. Does that sound right?
Short version:
- I'll take the cover off once a week to brush. Other than once a week, can I keep the cover on all year?
- I have a suction side vacuum attached to a vac port, will that still work with the cover on?
- Will the water still circulate properly?
