So confused with measuring and order of things
Zoilaa
18
01752, MA
11000 gal pool inground
vinyl liner
sand filter
CYA & chlorine are 0
pH 7.3
Alk 30
Obviously Need to add CYA. Do I add it now and start the SLAM and then measure it again in a week?
Ph is OK, But alkalinity is not is this a problem? According to pool math I need to add 15 pounds of baking soda should I do this now or latet does it matter?
Pool math is also telling me to add 1 gallon by volume of sanitizer for SLAM I don't know what this means.
HELP and tjank you
Update' I added a little less than 2 lbs of CYA to skimmer basket and 4 gallons of sodium hypochlorite 10.6% with pool on filter. Supposed to be hot and sunny tomorrow so wanted to get a head start.
Add 30 ppm TA worth of baking soda.
Add 30 ppm CYA worth of stabilizer using the sock method. (check how much you have already added).
Follow the SLAM Process
