Hi,
TLDR; I've been hit with algae and I can't SLAM it out. Help?
In the past few weeks there were a few days of very heavy rain. This, combined with the fact that I let FC drift too low resulted in algae taking over.
I started SLAMing 5-6 days ago. Last year I would get quick results, but this time (first time this year) it's the longest it's ever been with no visible results. I'm stumped.
Since starting SLAM, I vacuum every morning (to filter) with a "dumb" suction side cleaner, then brush walls and floor and backwash. Backwash is always 100% clear. I also brush walls and floor in the evening before adding more liquid bleach. I use the TFP app to calculate chem amounts and log levels. Pump running 24/7.
Jun 19
FC 2.0
pH 7.4
This is when I let the FC drift too low, big mistake. Will shoot for min 5-6 from now on.
Jun 22
CYA 40
Add 600g trichlor
Add 500ml of 29% acid to bring pH down to 7.2
Add 1.5L bleach 10.8%
Jun 23
Add 3L beach 10.8%
Jun 24
FC 12.5
Add 2.2L bleach 10.8%
Jun 26
FC 16, pH 7.4, TA 70, CYA 40, TEMP 72F
Jun 27
FC 12
pH 7.8 (or 7.2?!)
Add 600ml 29% acid. (I forgot that pH readings are affected by 10+ FC)
Add 345g alka+ (because of TA 70, but maybe that was off too because of 10+ FC?)
Add 2.5L bleach 10.8%
Jun 28
Add 2L bleach
Add 400g trichlor
FC 18
Add 1.5L bleach
At this point even though I'm above FC 16, I'm thinking with CYA being ±10, I'm going to add more bleach just in case.
Had some algae film in the skimmer, which was a first ever. (now gone)
Jun 29
FC 25
pH - 8.0 (or in fact 7.2?!)
Maybe I went a little overboard with the bleach. However, it made no difference. This morning is like every other morning: algae all over the floor and walls, and the bottom isn't visible in the deep end.
Questions
The dark side is calling, that algicide is starting to looking mighty tempting. Help and thank you!
Jun 19
FC 2.0
pH 7.4
Jun 22
CYA 40
Add 600g trichlor
Jun 23
Add 3L beach 10.8%
Jun 24
FC 12.5
Jun 26
Jun 27
FC 12
pH 7.8 (or 7.2?!)
Jun 28
Add 2L bleach
Add 400g trichlor
FC 18
Add 1.5L bleach
Jun 29
FC 25
Questions
- Why isn't FC 16+ yielding any visible results?
- What are my next steps, should I just maintain FC 25 and keep vacuuming in the morning and brushing twice a day?
- Should I add muriatic acid?
