sjfrank
13
Connecticut
So right now the pools doing pretty good, would you recommend SLAM at this point in the summer or wait until next spring. I didnt realize you could use the pool during the process but that actually makes sense. I planned on doing SLAM next spring. I did "shock" by adding a container of liquid chlorine after 4 days of torrential rains but other than that its been fairly stable..not great. I bought the strips before I found TFP and will dunk one once in a while but wont get new ones.
Moved from here.
A SLAM is not part of routine maintenance, only to deal with algae issues. If you see algae or your fail the OCLT, then it is time to SLAM. If not, just maintain your chlorine correctly and you will hopefully never have to SLAM.
