Hello!
I have a first question for this forum. I need to slam my pool which is 14,000 gallons before I winterise it. Yesterday I got the test kit which allows me to work out my CYA levels and I think they are zero (Not holding FC at all).
So I was wondering, could I use the stabilised chlorine granules that I have to do a slam and raise the CYA levels at the same time?
I will then use the TFP method as i have a load of 11% liquid chlorine. I just thought it mught be good to use up the granules as i have no pure CYA yet.
PH is 7.6
FC is effectively 0
TC is slightly more than 0 but not by much
TA was 110 last i checked.
14k gallon pool - how much of the granules (dichlor I think) should I be using to raise CYA and to shock please?
Thanks so much in advance!
PH is 7.6
FC is effectively 0
