Traditional "shock" methods are to cover up the inherent problems with chlorine pucks. Most weekly pool services visit once a week, dump some pucks in, and shock the pool. This raises FC high enough to give the pucks a head-start on maintaining FC. As the week goes on, FC inevitably drops below minimum. CYA, all along is rising, making the FC less active, requiring that "shock" to stave off a green pool before the next service.
Eventually, CYA goes high enough to make this all break down and a water exchange is needed or more expensive potions are used.
There's no need to shock. The TFP method is built on just keeping FC above the minimum - that's it. If you keep the water sanitary, there's no need to do anything else. It's really that simple but that's so out of whack with how the pool service industry and pool stores work today.
SLAM is a process to eliminate algae - there's no need to ever SLAM unless FC is not maintained and algae takes hold.
