My first post (a week or so ago) was regarding the use of PhosFree (pool store said my phosphates were extremely high). As suggested by the forum, I returned it, and instead purchased a TFT100 test kit, which I just received yesterday. This was regarding my (continuing)
So last night I started SLAMing. CYA is 45 (from the "black dot" test, which is the same reading from my AquaChek 4-way test strips).
The FC chart suggested a shock level of 18, which corresponded to 2-1/2 gallons of liquid chlorine (I used 8.25% in the calculator, which is what I had at home at the time).
I added this last night, and (as I suspected it would) this morning I'm back to "0".
I added another 2-1/2 gallons of liquid chlorine (Walmart, 10% pool chlorine).
The recommendation is to test max once/hour, min 2x/day, more frequently during early SLAMing process. However since I'm at work, I won't be able to re-test for 9 hours. I expect when I do, the level will be back to "0".
My first question is, will this schedule work, or is it necessary to raise the FC back to 18 before it hits some minimum, and what is the minimum? (guessing maybe 3ppm?).
Second question is about measuring the CC. When I added the powder to my sample, it remained clear (no chlorine apparently).
I added 5 drops of R-0003, sample turned pink.
I added 1 drop of R-0871, and it turned clear (.5ppm CC).
Then as I moved on to test the Chlorine and PH using the comparator, I noticed that my CC sample (still sitting there) had become pink again, so I added a second drop of R-0871.
So my second question is how long should I be waiting between drops of R-0871? I initially thought my CC was .5 (which is a "good" reading), but adding another drop later on changed the CC reading to 1.0, which is "too high" (according to SLAM).
Thanks!
problem of not being able to keep a FC reading above "0".
Thanks!
