Just started the slam process. I entered my numbers into pool math and added the required chlorine. The process has begun.
Pool water is clear, and fc/cc are both 0 due to draining a bunch of water to lower cya.
Salt is low, but waiting to add that until after the slam.
How long after adding the initial dose of chlorine should I wait to check FC and CC? Pump is running about 2500 rpm, I think (the speed I use to circulate water to the solar heater).
I added the chlorine in the shallow end, in front of a return jet. I assume i should test it in the deep end?
Ph is slightly low (7). I forgot to add some baking soda before the test. Should I do this now? Or worry about it after slam? I thought that low ph is better than high ph for slam, but honestly don't know why or if I misread that.
TIA!
TIA!
