Currently in the process of a pool-opening SLAM. Water is clear, but liner is stained dark green / brown on the walls and floor throughout the pool except for below the return where bleach is added - I am presuming this indicates it’s likely organic staining? It’s similar to the “ring” left by the winter water. It doesn’t brush off and my understanding is that it should fade with time if the FC levels are maintained properly for my CYA level (currently 40). Is this correct?
here are my SLAM-relevant numbers from last night pm and this morning am:
FC: 14 13
CC: 0 0 or 0.5 (turned back to slight pink after it sat for a minute - not while mixing)
ALK: 100
pH: 7.5
CYA: 40 (between 30-40)
Should I allow FC to trickle down to maint levels at this point, or is there any benefit to the stain removal process in keeping the FC level elevated?
FC: 14 13
ALK: 100
pH: 7.5
