Hey everyone! I've SLAM'd a couple times in the past and had great results, but this time having no improvement the past 3 days.
Pool had more algae than ever before (we were gone on a longer trip, didn't put enough chlorine in before leaving I guess, whoopsies). Started a SLAM with the following numbers:
-FC 2
-PH 7.2
-TA 30
-CYA 30
Been SLAMming with FC between 12-14. Have been brushing pool daily and cleaning/spraying my cartridge filter daily. Checking FC twice a day to maintain shock level. Initially there was some good reduction in the green (a week ago) but the past 3 days there seems to be no improvement. The pool is much less green and now much more cloudy, but I still get green algae accumulation on the walls, which I figured should stop because the FC should be high enough to prevent that right?
I'm wondering if I should maybe let the FC drop back down to 2-4 area and re-test TA and PH in case that's negating the chlorine? What do you think? Thanks as always!
-FC 2
-PH 7.2
-TA 30
-CYA 30
