G
See, this is where I am needing more help. I am trying to read and apply what is in the pool school and that calculator, but honestly, I am not sure I am on the right path or using the information correctly. I am using a good test kit now but, well, am starting to feel like I am trying to play football using a baseball handbook. And, with no one helping it is frustrating.supertune said:I'm pretty new here, IMO, your FC of 2 is way too low for your CYA level at 100 (too high for me, 60-70 would be the max.) If you used a good kit to determine that it is correct reading. You need to be at a minimum of FC 7, I would get it to 9-10 to start until you learn more about what your pool is needing. I would also like to see the T/A lower also, but others here with more experence can help.
Use this chart http://www.troublefreepool.com/pool-school/chlorine_cya_chart_shock
Use this calculator for amounts to use http://www.thepoolcalculator.com/
For reference to learn what to do, read and study this pool school http://www.troublefreepool.com/pool-school/
I will test CYA again today after dd's dr appt. It is possible I was reading the black dot test wrong because I have only added bleach. Thank you for telling me how to redo it. That helps reduce test taking anxiety LOL.dattia said:I know it can all seem like TOO much at first, but I promise, you will get it!
I am confused about your CYA number... and it is one of the most important numbers to be accurate on as it determines the amount of chlorine you need to keep your pool in a safe condition for swimming. The number you posted when you got the new kit was 80 and the number today is 100. If you were only using bleach, I don't think this number should have risen. You are using the Black Dot CYA test, right? It can sometimes be difficult to read. Often times, I will read this test several times from the same sample until I am sure of my reading. You can do this just by pouring your sample from the DOT vial back into the mixing bottle and then back into the DOT vial again. Do this until you are confident in your result. As I said, your FC target and shock value will be determined by your CYA number.
It is good that your water is clear and you have no CC's, but keeping your FC at the recommended levels for your CYA is the only thing that will keep it that way. As it stands right now, your high CYA value means that you will need to add bleach in greater amounts just to keep your FC at a minimum level and that is why partial water replacement was recommended.
If I am understanding it all correctly, I need to raise my FC to about 7 because my CYA is high.
Perform the Overnight FC Loss Test (OCLT)
The purpose of the overnight FC test (OCLT) is to determine if you have living algae, or other organic contaminates, in your water. If you do, you need to shock, or continue shocking, the pool.
Chlorine is consumed by two things: sunlight and breaking down organic contamination in your pool. By testing at night, we rule out sunlight. If chlorine is still being used up, it must be because of algae or other organic contaminates in the pool.
Of the common chlorine tests, this test can only be done with the FAS-DPD test. Test strips, and the OTO and DPD tests, do not have enough precision to determine if small amounts of chlorine are being consumed.
To perform the overnight FC loss test:
If you have an SWG, tablet chlorinator, or other chlorine feeder, shut it off completely.
After the sun goes down, and at least 30 minutes after your last chemical addition of the day, test your water for FC using the FAS-DPD test.
Record that result. Do not put any more chlorine in your pool.
The next morning, as early as practical and definitely before there is any direct sunlight on the pool, perform the FAS-DPD FC test again and record the results.
If your FC level remained the same, or went down by 1.0 or less, the water is clean. There isn't any living algae or other organic contamination in the pool.
If you lost more than 1.0 ppm of FC, then there is something in the water that needs to be removed and you should shock, or continue shocking, the pool.
