Is there a reason not to totally drain the spa?
I will still clear all return lines and blow out spa drain.
My my only concern is that totally emptying it won’t create an air lock. If that is the case should I leave some water in?
I was originally planning on lower below spa return and above light, somewhere near bench level.
Will add add a couple gallon containers for freeze protection.
Thoughts on leaving water in or totally draining?
