+1 for Calimar 3HP VSP. I'm using it on my 25k gallon IG pool. The Calimar replaced a Hayward 1.5HP single speed super pump. The Hayward wasn't broken, I changed it preemptively. I installed the Calimar pump and a Blue-White flow meter from Amazon. As an engineer (grin!) I wanted to know if I was over-driving my filter, pipes, etc. At 2700 RPM's and my config (very low head), I'm getting about 55gpm flow rate thru the 1 1/2" pipes and filter, which is the perfect flow rate for my filter. Flow rates are higher if I put the filter in bypass mode.
The pump was inexpensive enough that it was a no-brainer to get the 3HP AND the extended warranty. I run 2 two-hour periods of 2700 RPM, and 2 nine-hour periods of 700 RPM, and a 2 hour rest period. I'm saving about $50/month on my electric bill as well.
IMHO, the manual doesn't completely describe how to use the control panel, so it took a little trial and error to get to where I understood it, but I'm golden now and very happy with my purchase.
Hope this helps...
