- May 11, 2021
- 973
- Vinyl
- CircuPool RJ-30
Yesterday I had several kids in the pool... in the evening water was clear but got 1ppm CC on when tested (FC 2, CC 1, TC 3, CYA 20 **, PH 7.5), so I added enough chlorine for 10ppm (I didn't use pool math all the way and didn't account for the 2ppm I already had, so ended up with 12ppm rather than 10ppm) and went to bed.
This morning the water is still clear, TC dropped from 13ppm to 12, CC is at .25ppm (My CC barely register, so I guess it is lower than .25). So, SLAM stop criteria met.
My questions are:
Should I have SLAM in the first place or should I have just got FC up back to 5ppm to see if it alone would take care of CC?
As long as water stays clear and OCLT is below 1ppm and CC is below .5, is it OK to stop slamming even if it was on shock level overnight?
Does a solar cover impacts OCLT when slamming?
What about my extra 2 ppm, does it affect OCLT in any way?
** Yes, CYA is low, but for a reason. Going to have to rely on Trichlor for couple week and dont want my CYA too high on the begining of the season.
My questions are:
