I have an above ground pool with an "Outdoor Pro" cartridge filter. There is a drain plug at the bottom I need to take off to drain the tank with when I want to clean the filter. The water runs all over the electrical and everything due to them being right there. I was think how cool it would be to screw in a little valve with a handle, then i could hook a hose up it and just turn the valve when I need to drain and run in out beyond to the ditch. Any consequences to this? Can anyone recommend a valve? Here is a pic of my drain plug. Not sure what would fit it. Was looking at this but wondering if it is the right size, or if it would work? Hayward Trimline 2-Way Ball Valve
