Should I open this box from T S Pool Supply?
Hudsonbard
22
Hudson Highlands, Orange County, NY
Pentair Intellichlor IC-40
This box in the photos below makes me a little nervous.
This prior thread also does not inspire too much confidence. T S Pools
There are a number of one star reviews on Amazon, because they are ugly on returns.
On Amazon, T S Pools say for unopened box returns:
30 Day Return Window FOR UNOPENED BOXES ONLY
Item must be unopened, unused, uninstalled, and re-sellable condition. Customer responsible for all shipping charges to and from.
Customer responsible for all shipping charges to and from TS Pool Supply. This will be deducted from any valid returns.
The story is I found online that cleaning my existing SWG should be a piece of cake, and I could have better control than relying on my pool company. However Orange County Pools made the hand tightened unions so tight the threads of one union were stripped, two strong men could not open it with a crescent wrench and a plumber had to use a 2 foot long wrench to get it off. Meanwile I had broken a PVC elbow in my attempt. So I had my plumber repair the piping so I could keep using the pool. Amazon seemed the fastest way to get a replacement. I did not check out the seller before ordering.
So now, I can open the box, gambling that the unit is good. If not, I would have to rely on Pentair to solve any issues.
Or, in the alternative, I could return this unit through Amazon. Seller will deduct freight, no doubt overcharging and delaying payment. And order from a supplier with more integrity.
There is no perfect choice at this point. What do the gray beards advise?
My IC60 from a top notch supplier had the same warning. The majority of failures happen outside of the warranty period. Pretty much if it runs the 1st time, your chances are as good as they're going to be.
What size cell is it supposed to be? I don't see a clear marking on the box.
Hopefully an IC40 or IC60.
Thanks for your reply. I guess I'll let the plumber install it. This forum is so important for pool newbies like me.
My box had the same thing.
If I recall correctly, you could open the box from the bottom without disturbing those seals......
not that I would have done,that.
