Hi all,
I have a few questions.
Should I open early, about mid April? I'm guessing the pool water will still be green even with the cold temperature, due to not opening last year. Maybe a good idea to get a head start.
I read in another thread that someone who did not open their pool for 2 years, had trouble getting clear water because it had foam on top, possibly ammonia and someone recommended to remove some of the pool water and add fresh water.
Should I do the same? if so, how many gallons?
As recommended here, I use the BBB method but when I am Slamming and clearing a swamp is it possible to use shock chlorine instead of liquid bleach? I am aware it is against the Pool School instructions but is there any powdered or granular chlorine out there that does not have stabilizer?
Is it easier to maintain a clear pool in the summer months with a bit higher FC level, say about 8-9 and CYA at 50-60 and/or maybe adding Polyquat 60 algaecide as a preventive measure? I had some black algae 2 seasons ago.
35k Gal, IG vinyl, Tagelus sand filter TA-60D, Hayward Super Pump 1.5HP, SP1610Z1M,
Laars Lite NG Heater, Taylor k-2006.
