Should I add salt?
Flbeachluvr
397
Port Orange, FL
#1
My salt levels have held steady since our pool was built until I tested tonight. It usually runs right at 3400 but it's now at 3000. I do have the Taylor salt test kit. Pool Math tells me to add 29 lbs. of salt which isn't even a full bag as I understand they are 40 lbs. Should I go ahead and add the approximately 3/4 bag? Any special instructions on how to add it? SWG on or off? Shallow or deep end? I'm assuming I should brush it around so it doesn't just sit on the bottom? I also think I read something on this forum about the Clorox brand salt staining the bottom of the pool so I'm going to avoid that brand.
YippeeSkippy
9,231
Evans, Georgia
#2
Is your SWG producing FC without any error lights coming on? If so... I wouldn't do a thing. A happy SWG is a happy pool owner! When it gets unhappy, then you consider it.
Maddie :flower:
JoeGolan
200
Palm Coast, FL
#8
With my kit. The SWG actually says 3100.
Slight differences in readings from SWG to testing is normal, I actually try and keep mine in the middle of the range of operation which is 2700-3400 so your numbers look great to me. I wouldn't add any salt now, your initial drop in salt saturation is most likely due to all the rain lately in Port Orange and if you had to drain your pool to maintain a proper water level you are also draining away salt. Salt doesn't drop its levels from evaporation only dilution, in fact evaporation actually increases the ppm numbers of salt.
OP
OP
Flbeachluvr
Flbeachluvr
397
Port Orange, FL
#9
Yes, exactly. I did have to lower the water level recently due to all the rain we've had.
