Good Morning fine folks...
My wife and I just purchased a new Spa (Master Spa Twilight 8.25). In an attempt to keep this brief, the spa comes with an Ozone, which I have read that Ozone breaks down chlorine. I am struggling keep chlorine in the tub, as the ozone always breaks it down to .5 or less. So there are times where the tub is running down to 0 which has caused slightly cloudy water at times. I am able to correct it, but I never realized how high maintenance a tub could be? I feel if I don't put chlorine into the spa at minimum twice a day, I run the risk of running the chlorine to 0. So with that back story, I started to explore salt cells as we have a salt pool which is super low maintenance. I found this one that appears to be large enough and made for spas. I guess my question is will it produce enough chlorine to maintain the spa, outside of maybe an extra dose of chlorine after we use the tub?
I have been putting 60 mL of 12.5% chlorine in after the spa is used by two and in the AM to maintain the spa. Water chemistry is okay, outside of PH has also been a little bit of a battle, but it sound like that is expected with all of the aeration that happens within a spa. If I am missing something, please poke some holes in my process.
Thank you all!
Justin
Thank you all!
Justin
