There is really no need to have the tabs in while doing a SLAM Process. They will just increase your CYA which will require a higher FC level. Can you just pull the tabs and let them dry for use later? But to answer your initial question, if you have tabs in a floater or an inline chlorinator, you can add liquid chlorine at the return jets. That's fine. Just don't mix them directly together.
I went back and checked your other posts, so I'm deleting my comment about your testing. I'm now assuming you have the proper test kit to get things rolling! Keep us posted
