SETTING UP OMNILOGIC TO OPERATE PAL 2000 COLOR LOGIC DIGITAL LIGHT VARIATIONS?
navyeodcm
1
Navarre, FL
I'm in the process of having an entirely new pool filtration system installed to include the OmniLogic control center. WRT my PAL 2000 Color Logic lights, I can control the on/off function only from both my OmniLogic app on cell phone and website via laptop. There are quite a few separate color schemes inherent with these lights, but only one coming up when turn lights on. Tried cycling on/off to see if the scheme would change each time, but it doesn't. Would really appreciate any insight/assistance on what I can do to enable these lights to work like they are designed.
Anyone? I figured out there is an app for PAL which will allow you to change the color scheme. However, it is a pain in the butt, because you have to disconnect from your home wifi and connect to a PAL wifi. Then, in order to reconnect to the omnilogic, I have to connect back to my home wifi. I have sent a question off to PAL to see if there is an easier way, but haven't heard back yet.
The Omni should basically act as a light switch with your lights. I know this sucks to have a $2000 automated system and not have any special control, but it basically turns the light on using a relay and that's all it does. The problem with this sometimes, is that the relay doesn't turn off, then on fast enough. In this case, this is PAL instructions on changing color:
To advance to the next color mode just turn the
light switch OFF then ON within 1.5 seconds on
each color advance until you select the required
color mode.
Your Omni may not be turning off/on in the required 1.5 second timeframe.
