Setting up a RS-6 Spa Only Help
Nov 20, 2022
5
SoCal
I have set up Combos before but not Spa Only. As I have read here, there is no Spa Mode with a "Pool" or "Spa" setup.
So I set up Temp 1 to be 104 but how can I set up the Four Function Spa Switch to:
1. Start the Filter Pump
2. Select Temp 1
3. Start the Jets Pump
4. Stay on for two hours then return to normal schedule?
I created a One-Touch called Spa-Mode that works from the web interface but I cannot choose that as an option for one of the Four Function Spa Switch buttons.
Thanks in advance
Welcome to TFP.
With a single body of water there is no separate POOL mode or SPA mode.
Turn on the filter pump and you are in SPA mode. That is your switch 1.
