Seriously odd question for the techs
No. The sloan led is smaller than 1/4" I think, as is the inside diameter of the fitting. What I meant by hole size is the hole you drill in the spa to install the fitting, so the outside diameter of the fitting at the threads.
5mm is less than 1/4", and I understand what you meant with the hole size.
Reactions: RDspaguy
Thanks man! Looked all over for that.
I search in 7106 different languages just to be thorough.
