I was doing some math and came up with the following calculations on cost of Bleach vs. Cal Hypo for adding FC to my pool:
12.5% Bleach: 20 oz. raises FC by 1 ppm. Cost $4 per gallon. Cost per 1 ppm FC = $1.60
68% Cal Hypo: 4 oz. raises FC by 1 ppm Cost $100 per 25 lbs (400 oz.) Cost per 1 ppm FC = $1.00
So... at the prices noted above for bleach vs. cal hypo, I am saving 60% by using cal hypo.
Now, I know cal hypo will also raise my CH ( about .7 ppm for every 4 oz of 68% cal hypo) so I would have to keep an eye on that. However, I am usually adding 1-3 inches of water per week to my 20k pool, so I assume CH is always dropping a bit with the fill water and/or rain water.
Because of the significant difference in price, I'm thinking that it makes sense to use cal hypo to chlorinate my pool until my CH is approaching the upper limit recommended by TFP (350 ppm). (Right now I am at 270 ppm on CH.) I might even be able to get through a whole season (about 4 months here in Chicago) using cal hypo if I start the season with CH at 250 or lower, which I think it should be after first filling the pool for the new season.
I would greatly appreciate any comments form the TFP experts on my calculations and/or plans to use cal hypo as primary means of chlorinating.
BTW..... I didn't even figure into the equation the cost of purchasing calcium hypochloride separately to add CH to the pool when needed.
