I have a fairly good crack in the bottom of my pool. It was there last season and I tried using A/B epoxy, but it didn't seem to work well. First of all I had trouble mixing it since it was such a large amount. The crack is pretty narrow but one side of it is popped up a bit from the other. So when I made a good sized piece I didn't feel like it got in place well.
Anyhow I noticed someone on another forum mention fiber glass cloth and underwater epoxy together. I had not come across that during my research last year, does anyone know how that would work?
I didn't know if I should try someone else underwater to seal under the lip, then put something over the top. Or if there is a better product to use in my situation than A/B sticks.
Side note, I do know this is not a perm solution. The quotes to drain and fix the FG are over 3k. So I am trying once again the squeeze some time out of using it.
I am just trying to come up with some temporary fix to keep the water from leaking.
Let me know what you guys think.
Thanks
Thanks
