Hi all, before diving into my question, I did find quite a few threads on this topic, but none had such a big difference between CSI and LSI (Taylor Waterwheel) that wasn't explained by some sort of calculation error. Maybe my issue is also some calculation error I am just missing. I know the waterwheel provides less different measurements and leaves out many parameters but the differences between the two are very different so I wanted to get some clarity, in particular, before adding calcium, which would push me further away from a 0 balance on the Waterwheel but near 0 on the CSI provided by Pool Math.
Measurements Today all with Taylor Kit and Goals:
temp 78 degrees F
FC 6.5 -> hold
pH 7.7 -> hold (range 7.6-7.8)
TA 80 -> hold
TH 400 -> plan to increase to 450...maybe even 500.
CYA 70-> plan to increase to 75
Salt 3100 -> added salt today to increase to 3300
Borates (based on test strips) 40 -> hold
On the pool math, the CSI for my goals amounts to -0.09 but on the Taylor Waterwheel I get almost +0.40. None of the other threads I read had this big of a discrepancy that wasn't explained by something else. The "further reading" post on this subjects states "Do not get hung up on the "which is better" debate, as that is a false choice. The indices are simply measures of how stable calcium carbonate is in solution. You can use one or the other; both will give you the same general answer." but its hard for me to not wonder which is "best" with such big differences.
In general, trying to aim for slightly positive in balance, hence my desire to push CA higher in the "ideal" calcium range. The owners before me seemingly added almost no calcium to the pool and there seems to be a lot of what I assume is corrosive damage to some of the rocks around my pool. But I am open to learning and suggestions!
Thanks in advance for any help.
temp 78 degrees F
FC 6.5 -> hold
TA 80 -> hold
