I have seen quite a few postings where sand has been found on the pool floor? And I was wonder, if after the line left the filter to the pool, if within that stretch you insert a t fitting and have a down pipe connected the longer the better, with a clean out at the bottom, do you think sand leaving the filter would collect at the bottom of the tube, as the sand is heavier than water, or is the force not going to let this happen?
