Sand Filter valve settings mislabeled
Aug 12, 2011
93
Augusta, Kansas
Intex Krystal Clear
Hi everyone,
We replaced our Intex pump over the weekend with AQUASTRONG 16in Sand Filter Pump for In/Above Ground Pool with Timer, Max 3800GPH for Pools Up to 16000GAL, 6-Way Valve. The new pump and sand filter are connected, and water is moving. I have learned that the label on the multi-port valve is so wrong. I learned this as I trying to backwash and noticed I had "very clean" water coming out the hose (and viewing it through the clear blub). I went to Amazon reviews and noticed others saying the multi-port valve is mislabel.
I have found the following by trial and error:
  • Closed is really Backwash (water going out the backwash tube was FILTHY and nothing going into the pool - ran it until clean)
  • Waste is really Rinse (water going out the backwash tube had some sand twirl though it and then settled to clear and nothing going into the pool)
  • Rinse is really Closed (no water came out of anywhere)
  • Backwash is really Waste (water going out the backwash tube nothing going into the pool but water exiting was clear)
My question for everyone is how do I determine the final two Recirculate and Filter? I know the two positions that send water into the pool. How do I tell if the water is going through the sand or not?
Reactions: listensoft
