We purchased a house 4 years ago with a pool. At that time the sand filter was clean at 10 psi. Now it is reading clean at 18 psi. What could be the reason for change on this? The sand was replaced 2 year ago so that shouldn’t be an issue.
FC - 3The first place we would is a fresh set of water test results. Let's see those so we can evaluate teh chemistry.
Three days ago. The pressure when dirty rose to 25 psi on the gaugeThose numbers look pretty good. Could use a little more chlorine, but okay. When was the last time you backwashed?
How would I know if my pump speed is higher? I have Hayward single speed 1hpIf your pump speed is higher than before, than will increase the pressure.
Then that wouldn't apply. In my case for example, I have a 2-speed so my pressure is much lower on low than it is on high.I have Hayward single speed 1hp
