- Apr 29, 2023
- 16
- Vinyl
- Intex Krystal Clear
I have a 4700 gallon Intex pool, with the included small (0.18 hp) pump and 10" sand filter. The system is adequate, but barely. I can only run the vacuum on "recirculate", and must backwash a couple times a week. The difference between "clean sand filter, full flow" and "too low flow for heat pump to run" is only about 3 psi.
I'm planning on upgrading the system to add a more powerful pump (0.5 to 0.75 hp) and a larger filter.
My question is whether I should stick with a sand filter, or switch to a cartridge (maybe with a vortex prefilter) for this small system. I didn't realize that filters are a viable option for these small pumps, but my small amount of research indicates there may be advantages over the sand filter.
Any thoughts or experiences on this?
Much appreciated!!
Much appreciated!!
