Sand bottom for in ground pool
rhaymg
10
Georgia
I'm having a vinyl liner inground pool installed. I am in SW Georgia.
Apparently, the price of Palmetto poolcrete has increased and the builder wants to put in a sand bottom instead, not sure if it's just sand or a mix. Should I be concerned?
Thanks!
I am not a pool construction expert, but sand bottom for IG vinyl pool is okay, hopefully they give you the appropriate cost adjustment.
Make sure they level & compact it so there is no settling later on.
I would push for poolcrete or vermiculite, especially if that is what you were quoted. Too easy to put footprints and other divots in a sand bottom, which show up like moon craters at night with the light on. Bottom of a vinyl pool will never be perfect, but I would worry that a sand bottom would look beat up long before you need a new liner.
Reactions: proavia
