High chlorine levels will give a false high pH reading during a SLAM so you are probably good. Adjusting the pH to normal levels before a SLAM is best and you had it at 7.6 last week so it is probably good.And, I just checked CYA and pH....CYA appeared to be 30 tops? I always have trouble with that little black dot, ugh. And pH was back up to 8, after lowering to 7.6 last week. Is the SLAM messing with that? I have some stabilizer in a sock in front of return right now, but what is best way to deal with pH while SLAMing? I feel like one thing gets better and 3 other things get worse. This is where pool ownership seems overwhelming to me?
The CYA is probably good at its level now because increasing your CYA too much will cause you to have to use more chlorine to get to SLAM level.
Just for FYI: Today I've been SLAMing the pool all day. Started off at 10.5 this morning. Added to get to SLAM which for me is 16. A couple of hours, I checked the chlorine level and it dropped below the SLAM level. So I add more and get it to a couple numbers above. I'd taken it up to 16 and 2 hours later it was down to 14 after vacuuming and brushing. So you see how the SLAM is important to keep it up high, checking it frequently till the pool is clear. Its still cloudy but improving, much clearer than this morning but I have to stay on top of it.
As TFP says "You need some P.O.P. = pool owner patience.
