- Nov 15, 2022
- 58
- Plaster
- Jandy Aquapure 1400
I'm going to convert my pool (back to) saltwater and looking for some input and advice as I plan things out. My pool is around 11,000 gallons.
For a little background, when I bought my house, the pool had a saltwater system installed, but the cell was depleted, the controller was disconnected and the pool was operating as a regular chlorine pool. Then we had a hailstorm that damaged pool equipment and we replaced a bunch of it, including the saltwater control unit. We had the salt cell removed during the repairs since we weren't using it and at the time we didn't plan to.
The controller is a Jandy AquaPure (model APUREM) and the cell I got is a Jandy AquaPure PLC700. I also decided to get a sacrificial zinc anode, but couldn't decide if I liked the PoolTool or the CMP Pool Defender better, so I got them both and will return whichever I don't use. I also ordered a Taylor K-1766 test kit to help get the salt levels correct.
The questions I have are:
- Which anode to use? The PoolTool seems very widely used and has a bleed valve which seems like it could be useful? The CMP is a little less expensive and also does water bonding, but no bleed valve. I don't really have much metal in the pool - really just the light fixtures and a couple loops for a volleyball net. I do have a heater (Jandy JXI400N) and not sure if it has an anode in it or not. I'm also not sure if the light fixtures are providing water bonding or not.
- I assume I need to get the salt level in the pool correct before I fire things up? Can I install everything and have water flowing through the cell prior to that, and then turn the system on once I get the salt level correct?
- Anything I should learn or do ahead of time to prepare either for the installation or for ongoing operation of a saltwater pool?
