I have decided on Salt Water Pool. I am getting the contract ready. I saw PB has added the Clear Blue Ionizer at no extra cost but I did not see Salt System in the contract. So I asked him have you included the salt system (Fluidra Astral E35 Salt System) in it?
He replied, "No the clear blue ionizer. You do not need salt chlorine pool. Salt will corrode your travertine".
Will salt water do it? Should I still go with salt system as initially planned?
Will appreciate any comments before I sign the contract.
The pool that I am going with is:
Pool Specifications:
• Max Length: 30’
• Max Width: 13’
• Depths: 3.5’-5.0’-4.0’
• Pool Perimeter: 91’
• Pool Water Surface Area: 370’
• 9,430 gallons
Spa Specifications:
• Max Length: 7’
• Max Width: 7’
• Depths: 3.5’
• Spa Perimeter: 28’
• Spa Area: 49’
• 760 gallons
Pre-Excavation:
• Construction Drawings
• Engineer’s Letter will be provided to City and Homeowner
Excavation:
• 1.5hr. pre-grade for pool and spa
• Mini - Excavator
• Alley access for Dump trucks
• Does not include any utility or irrigation re-routes
Pool & Spa Plumbing
• 2- skimmer 2” sch40 pvc
• Dual main drains 2.5” sch 40 pvc
• 4- pool return jets 1.5” sch 40 pvc
• 1- spa spillway line
• 6- Hydrotherapy spa return jets
• Dual spa main drains 2.5” sch 40 pvc
• Gas line from meter to heater up to 50ft. included
Steel Reinforcement:
• 4- ½” steel bars run continuously through pool beam
• 1/2” steel bars 10”o.c. walls and floor
• Alternate bars at 6” o.c. floor transition
Gunite Shell:
• 8” minimum floor and wall thickness.
• 12” minimum Bond Beam thickness
Electrical:
• Homebuilder to provide power run to equipment location 100amp service
• Run wire over 200’ add 3.30/ft.
• Wire- Pool pump
• Wire Pool Light
• Wire Spa Light
• Crown to install Sub Panel at equipment location with Siemens Brand Breakers
Coping,Tile, and Masonry :
• Pool Coping - 12”wide – Travertine – Ivory
• Pool & Spa Waterline Tile- 6x6 standard
Pool & Spa Equipment:
• Astral QL540 Cartridge Filter
• Jandy Variable Speed 2.67HP pool pump
• Maytronics Active 20 robotic pool cleaner -$999
• Pool Defender- Zinc Sacrificial Anode/water bond $175
• Jandy Jxi 400,000btu Natural gas heater
• Jandy Hydrocool LED nicheless lights (3) - $1,197
• Jandy iAqualink wireless pool computer(pc,tablet, or smartphone controlled)
• Jandy 1.5hp Air Blower for Spa
• Control valves + Inline Chlorine Feeder
Pool & Spa Plaster finish:
• Includes all pool fittings, return jets, and drain grates.
• Wet Edge Signature Matrix Level 1 color Pebble Finish
Pool Start-up & Orientation:
PROJECT TOTAL __________________$ 64,107.67
Due at signing 5% : 3,205.38
Excavation 30% : 19,232.30
Gunite 30% : 19,232.30
Tile/Electric 30% : 19,232.30
Prior to Plaster 5% : 3,205.38
*NO LANDSCAPING, IRRIGATION RE-ROUTES , OR UTILITY RE-ROUTES INCLUDED
• Max Length: 30’
• Max Width: 13’
• 9,430 gallons
Spa Specifications:
• Max Length: 7’
• Max Width: 7’
• Depths: 3.5’
• Spa Area: 49’
• 760 gallons
Pre-Excavation:
- • Dallas Permit
Excavation:
• Mini - Excavator
Pool & Spa Plumbing
- • Based on 20ft. distance from water’s edge to equipment
Gunite Shell:
Electrical:
- • Up to 200’ conduit and wire
• Wire- Pool pump
• Wire Pool Light
• Wire Spa Light
- • Wire- Pool & Spa Computer controller
- • 1x1 glass tile on front side of spa
- • Clear Blue Ionizer – Mineral Pool System
- • Pool controller programming and orientation meeting
- • Pole, brush, skimmer net, leaf rake, & test kit
- • Start-up chemicals included
- • 3- months free pool service +1 Free Filter clean service
