Salt cell turn off after 30-40 minutes
The salt cell is mounted in that position. It is clean. The pump rate is 2950. Is that enough? Thanks
That should be fine.
Go to the diagnostic screen, note the readings and then press the + button to reverse the polarity.
When the new numbers appear, see what they are.
Then, press + again and note the new readings.
Report ALL readings.
When I changed polarity it takes about 10 seconds for the readings to settle. I did it four times
-25.8v, -6.4a, 3200ppm
+26.0v, +6.1a, 3100 ppm
-25.8v, -6.4a, 3300 ppm
+26.0v, +6.0a, 3000 ppm
Pool Temp was 74
