I understand this product is generally intended for use in commercial pools, but I'm curious if anyone has ever used or seen someone use this product (or something similar) for a residential cover. I have experience with these covers from many years ago, so am generally familiar with them, but I'd be interested in any feedback from people taking a similar approach with their residential pool. I would be talking about using this for a pool that is 60' long and something like 18' wide. I likely don't care to install an auto cover, but would like a durable thermal cover that could be used to help at least extend the season (paired with a heater) in Nashville -- and perhaps if insulation is good enough, keep the pool open through the winter (covered when not in use). Ideally it would be a cover that would be fairly easy to put on/off.
I suspect people may be inclined to comment that (1) this isn't a safety cover and (2) this cover is not the most aesthetically pleasing. I understand both -- I'm not concerned with the safety cover issue, and in theory this cover would be easy enough to remove that it could be removed as needed/desired (e.g. for a party, etc.), even in the relatively colder months.
