Rust inside of pool filter
GoldMember
Active member
May 12, 2020
31
Long Beach, CA
Hello all. Last month when I went to clean my pentair filter cartridges, I noticed some significant rust on the hoop that I think helps keep the shape of the filter housing. The filter is 5 years old. I assume this is stainless steel, right? Why/how would it be rusting? Is this a problem, or is this normal? Thanks everyone.PXL_20240724_201958624.jpgPXL_20240724_202003580.jpg
I believe this is a common issue.
It is pretty common. That band is not all stainless steel as you can see where the weld is will rust.
One day you may need to change out the band.
Reactions: GoldMember
It’s caused by the spot welds on the band. The manufacturer of that band, probably not Pentair, doesn’t use the proper post treatment processes to clean up the weld points. The welding process damages the stainless steel and causes it to recrystallize into a form of iron that is no longer corrosion resistant. There are ways to heat treat the metal as after welding to improve corrosion resistance but I’m pretty sure the maker skips those processes to save a few pennies per part.
FWIW, my filter is going on 12 years old, has the same band, similar rust issues, and works just as well as the day it was installed.
If you want to clean up the rust, use some Bar Keepers Friend liquid cleanser on a Magic Eraser sponge and it will remove the rust and restore the luster of the band.
I would also suggest redirecting the input water diffuser so it’s not totally pointed at the band. Maybe rotate it a few degrees either way.
Reactions: pjt and Mdragger88
